Gingy22
New to the tdi and i do not have vcds capability. The reason i ask is that I've had issues with a nox sensor code and VW wants to reflash my injectors, replace the injectors, replace fuel filter and housing and drain the fuel tank because they say the fuel (that passes VW quality tests) is an odd color and is not agreeing with the injectors that are throwing this code. Car runs fine just a P2201 code. New nox sensor and all. I say all that to say, i aint going through all that to fix a car that runs fine. But i do want to change the fuel filter. Ive owned the car for 3k miles (75k miles total) and im not sure when the filter was last changed. Is it possible to do this myself or do i have to have the computer to purge the system? I really do not want to take this car back to VW for the 5th time. 2012 passat TDI
