elvisvwvw
i was trying to find anyone do that kind of conversion on the internet.
so any help would be apreciated,
the car is 1.9 tdi 81kW
thank you that would be niceI got a JH head just sittin in a box, later on I will take measurements of a lifter for ya
you'd be better off getting a higher lift cam.
I think you are not understanding how a [properly functioning] hydraulic lash adjuster works. They do not vary the lift with oil pressure or engine RPM. The internal springs regulate that. I do not think a conversion to solid lifters is going to help in your goal of better flow through the head.my goal isnt to make engine spin faster but to improve intake and exhaust without porting the head , i thought that hyd. lifters had some problems when the oil gets hoter and more fluid... i mean that the oil pressure is a factor witch determines opening distance of the valve.and with solid lifter that factor would be eliminated
Yeah, funny though because both my 52hp A2s always felt signifigantly peppier than ANY of my 54hp A1s did, despite the A2 being a bit heavier. Must be the gearing.I will note that when VW switched from solid lifters to hydraulic with the 1.6L non-turbo diesel, they lost 2 hp!
So going back to the solid/mechanical lifters may very well yield a hair more power
