To the Original Poster, as Oilhammer has stated, there are a multitude of things that can be responsible for the AC Compressor Clutch not "kicking-in" when you turn on the system, directly or indirectly.
All those items need to be tested before doing a total Compressor replacement. My experience with the Sanden Compressors has shown me they are quite robust internally. If there are no obvious leaks (oil) and there is still refrigerant in the system, there's really not much of a reason to suspect the problem is internal.
So, again....... rehashing Oilhammer's list !
-Fan Control Module (FCM) is known to be problematic
-Fans out front gone kaput causing other issues
-Fuse on top of battery (left Green 30amp fuse, the other two are for the ABS)
-In dash fan switch. Without the engine running, that switch should turn on the Fans out front in AC mode. If not, that switch is bad.
-The AC coil behind the Pulley on the AC Compressor can succumb to heat. The two wires are Positive and Negative. Applying 12 volts to them will create a magnet snapping the clutch face tight against the pulley housing. If not, the coil is bad.
-The clutch face, I suppose, can go bad. I've seen them that have been obviously very hot but still worked.
-Low refrigerant switch can malfunction (it is mechanical internally)
-Low on refrigerant
-Ambient air temp switch go kaput (Also, critters have been known to chew the wires on that sensor.)
-Wiring problems
-Blower resistor in the fan housing on the passenger side
