dusty67
I have seen the fixes after you break it, but how do you not do it?
I can’t say whether there is consensus on this but I do it the way MOGolf describes here.Or cut the hose flush with actuator. Then use a pick tool (or something similar) to slip between the hose end and nipple. Then pick out the remnant. Probably no more than 10mm of hose shortened and there should be enough there for a reconnection.
