My AHU TDI is having trouble starting in the cold. It was about 30 earlier today when I started, which is hardly even cold and it took about 10 seconds of cranking. But every time I start after that first start, it instantly starts. And when it's warm out, like in the summer it starts instantly. I replaced all four glow plugs recently, and put the GPs on their own system with a push button. I held the button for probably about 15 seconds and it helped none at all. Starter is almost brand new. I got the static timing as close as I could with the *stupid* tensioning method for the AHU, and I set the dyamic timing dead on with VCDS. Injection quantity is good, although I wouldn't think that would affect starting. When I replaced the head gasket I checked compression and that seemed to check out fine. What I'm thinking the problem is fueling somewhere. I noticed while it's running, the clear fuel line will have a fairly constant stream of bubbles. I replaced the fuel filter with the new thermostatic part and new o-ring. So maybe I did it wrong. I used an ALH filter which has a different T-stat tee than than the AHU so I wasn't able to get the fuel lines all the way on, so maybe there is air coming in through there? I've also noticed that there's a constant drip of fuel coming from somewhere.. so maybe a bad injection pump seal??
