tongsli
disconnect the cable and squeeze the P-brake by hand. If it is the same, then it's not the cable.I have one caliper that just hangs up a bit so I put the springs on both sides.
Did nothing other than make the parking brake handle hard to pull up.
Will have to look at the lube trick.
I think my problem is my cables though.
I am in the middle of rebuilding a stock TDI caliper which was rusted at the stem below and underneath the P-brake and rubber boot. Last night I removed the rust and painted it with silver caliper paint.
