Thats a great idea, forgot about that forum.If you want info on making good power with VE pumps go poking around on 1stgen.org. Not all of it will pertain to the tdi pump but it should give you an idea as to the issues your going to face.
Interesting! Didn't know they did pump degrees in the software. Learn something new every day.don't confuse degrees crank vs degrees cam
you're running a wastegated turbo, right? Is the WG closing all the way, and on the other side of the coin, you might just not have enough fuel to spool the thing depending on the size of the turbine housing. Also, depending on which GT35, it might not like the pressure ratios that a TDI wants. On high PR low mass flow things like these, you generally don't want a high trim wheel that you see in low pressure ratio high mass flow gasoline applications.It's still fueling whatever I request of it, so that wouldn't explain why a non-regulated turbo wouldn't make boost.
Correct, not plugged in. The MAF was supposed to have been disabled, though I'm not sure if it was done correctly because the ecu still looks for it. I know the MAP limiter actually works though, because thats what I've been using to tune out excess smoke. I am trying to locate an N75 right now just to plug in.Not hooked up mean wires unplugged? With these unplugged the car will make no boost and fall on its face over 3000rpm. With the MAF disconnected the ECU will fall back to a safe max MAF value of about 500mg/str which will limit fuel/boost resulting in no power.
If you want to lose your MAF try searching for "MAP based tune" or similar, this way you can unplug your MAF and remove it from the car without issue. I'm sure the same can be done with the n75 valve but I can't help with that one you may have to leave it wired but un-plumbed for the time being.
No wastegate. I'm running A LOT of fuel. It's a very small turbine housing. Using what I know about how this turbo spools on other diesel's, I should be able to get it to spool by 3500-4000 with the magic of variable timing. And it follows my logic so far, it makes it's max boost of 4psi at about 2300rpm, before it flatlines.Interesting! Didn't know they did pump degrees in the software. Learn something new every day.
BTW, all of those codes are very easy to disable if you have winols.
What source do you have for this information? I doubt for it too. It would be quite easy to check how many degrees does timing piston movement allow sprocket angle movement and double it to have angle in crankshaft.don't confuse degrees crank vs degrees cam
stock the ALH is already 30+ degrees crank (but 15 degrees cam, same as 30 degrees crank)
If you take the timing "that's on the timing map" to 40 degrees, that's 80 degrees crank.
Isn´t really related for the topic, but I do not agree with this.You won't get 400 hp with off-the shelf VW injection pump
