chittychittybangbang
I no longer work on TDI and have these tool sets for sale. All are in perfect working condition except as noted, but may have minor cosmetic issues like scratches, stains, or surface rust. Prices do not include shipping, all sales final, no warranty implied on these used tools. Price is for 1 piece, not everything pictured, except as noted.
Make an offer on whole sets since I'll discount large purchases, but if you only want one or two pieces, prices listed are firm since I have to break up the set. Please reply by email for the fastest response!
1. Metalnerd counterhold tool for CRD engine with update kits, older engine pins included. $43
2. metalnerd ALH sprocket puller $47 1 remaining in stock.
3. SOLD OUT
5. metalnerd OR OEM #t10098a VW long reach cam tool for ALH. $36
6. metalnerd deluxe tensioner wrench. Price is for 2 wrenches, each with one pin broken on opposite ends. In other words, you get normal function with the 2 wrenches. $28
7. SOLD OUT
8. metalnerd OR OEM VW pin 3359 for ALH injection pump, PD cam sprocket, or CRD sprockets. $17
9. T10100, T10050, or metalnerd universal crankshaft sprocket tools. OEM VW T10050 is $25, OEM VW T10100 is $40, metalnerd universal is $36
10. SOLD OUT
11. SOLD OUT
12. t10051 OEM VW sprocket counterhold for PD or CRD. $48. 1 remaining in stock.
13. metalnerd 2064 injection pump pin for mk3. $12.
14. metalnerd OR OEM VW T10060a. This locks the serpentine tensioner in place for easy removal. Some minor bends but no change in function. $5 each.
15. 2 damaged pin 3359. The other end of the bent one works fine. The snapped off one with the red handle will work fine if you cut the plastic wrap of the handle off and use the handle as the pin. Discounted and sold as a set, everything in yellow box #15. $10 ($22 new)
16. 2 weird T10060a. One is shorter and the other is just a straight pin. Both work but are discounted since they're not OEM VW. Sold as a pair, everything in box #16. $3
17. Damaged metalnerd deluxe tensioner wrench. The upper end of the wrench has 1 broken pin. the lower end works fine. Discounted. $20
I also have 1 oil filter and 1 fuel filter for 1Z/AHU mk3 TDI Jetta or Passat.
Sold together, $25 shipped in the US.
3. SOLD OUT
7. SOLD OUT
10. SOLD OUT
11. SOLD OUT
