miatamike203
I'm doing this for a few reasons and mostly not just to make it an EGR delete. I want to try and offer people as many options for this as possible. One of the options i'm going to offer is different size pipes all made to order ranging from stock to what ever size you want to run your intercooler piping.
Also if you look in the stock ALH EGR valve the inlet size tapers down so there is a small off restriction in your EGR valve. Then add on the EGR portions for another small amount of restriction. Im not saying you will see crazy amounts of power from deleting your EGR in anyway. I do believe how ever there will be some sorta improvement by reducing any form of possible restriction. I also believe it will be a more noticeable improvement on a car that is heavily modded IE turbo, nozzles, intercooler and tune not a stock car.
I also have unlimited access to a dyno that i can use to see if there is if any power gain from having the race pipe.
The other thing im going to be doing is making the butterfly and shaft out of heat treatable stainless so in case you ever do have a run away you know the butterfly and shaft will be super strong and not fail. There will also be an 1/8" NPT fitting to be used how ever you wish. I can also offer anodizing and laser engraving. I have access to a lot of equipment and i don;t plan for this to be my only project that i could offer to people here as well.
