meerschm
- Joined
- Apr 18, 2009
- Location
- Fairfax county VA
- TDI
- 2009 Jetta wagon DSG 08/08 205k buyback 1/8/18; replaced with 2017 Golf Wagon 4mo 1.8l CXBB
http://pics.tdiclub.com/data/500/D3E802F8708-2_0L_TDI_Common_Rail_CBEA-CJAA.pdfI haven't looked at mass air flow. I tried to compute exhaust flow from rpm and boost pressure, correcting for exhaust gas temperature, but that product does not correlate well with the dpf differential pressure. Boost alone (or rather, manifold pressure) surprisingly correlates better, but the ratio still shows a lot of variation. What seems to be fairly constant is DPF diff.pressure divided by that exhaust pressure variable. That ratio is quite steady over a range of boost and RPM.
So, is there any other exhaust related pressure in one of the VCDS groups? The one I'm looking for is about 1.5 times the DPFdiff.pressure after a regen while driving , and closer to 1 times DPF before a regen. But I could also be imagining that; just knowing what VW/VCDS calls that pressure would help.
Matt shared this here http://forums.tdiclub.com/showpost.php?p=4912716&postcount=104
feel free to look around.
as far as i know, there are two differential pressure sensors in the exhaust system, one is across the DPF, the other someplace in the low pressure EGR path.
Mike
