2004 Jetta TDI sport PD timing belt change.
TDI MkIV
Ontario, Canada
2004 Jetta Sport TDI PD
Hello everyone,
I apologize if this is posted in the wrong section, I am very new to the forums.
Anyway, I recently purchased a 2004 Jetta sport, TDI which needs the timing belt replaced. I found a kit that includes the tensioners and the water pump. about $420 CAD.
I hope this isn't a dumb question, but is that a good price for a kit? It seems to include everything needed. I managed to find it cheaper online, this is through a parts shop.
Also, are the impellers on the water pumps interchangeable? Can I replace a water pump with a plastic impeller, with a metal one? I'm not sure which impeller my car has, I haven't ordered the kit yet, as I wanted to sort out this impeller problem beforehand, lol.
Thanks for your time.
Mongler98
COLORADO (SE of Denver)
Plastic to metal, yes. Do a search on here. Oh and go with our trusted vendors. There are some bad parts and vendors out there so stick with we know is good
bmwM5power
Rochester NY
15 GSW TDI S 6MT 02 JETTA TDI GLS 5MT 15 GOLF TDI SE 6MT 15 GOLF TDI SEL DSG
where did you find it? seems a bit steep for the PD engine TB kit
jokila
Houston, Texas
2003 Jetta GLS, Manual
Hello everyone,
This one is $204 USD which is $276 CDN.
https://www.idparts.com/timing-belt-bewtbkit-p-511.html
TDI MkIV
Ontario, Canada
The kit is from CarQuest, it's the OEM timing belt kit. The kit includes the tensioners and camshaft seal, as well and engine mount bolts. Sadly, I realized too late that there are definitely more cost effective options. lol.
Oh well.
Vince Waldon
Edmonton AB Canada
Roseland Technical Services (www.roselandtech.ca) has a very high-quality OEM BEW kit at a very reasonable price...and they are just a couple provinces to your left. :)
https://roselandtech.ca/timing-belt-kit-bundle-bew
(final price depends on what extras you order... you'll need motor mount bolts for sure)
Impellers are interchangable.. most people opting for a metal impeller if they can.
jokila
Houston, Texas
Oh well.
I am surprised it would come with the motor mount bolts. I was under the impressions those bolts are typically sourced through VW and added to a kit from the online TDI sites.
