Auto Dimming rear view mirror
Tdi Noobie
Waterford Michigan
2013 Passat TDI SE, 6MT
Has anyone gotten rid of theirs? I cant stand it. Problem I have is when its dawn, or dusk and there is a giant truck with its lights on behind me, the wont dim!!! Or if there is nobody behind you and someone pulls up, it takes forever to dim. I have had them on other brand cars and have had the same prob.
I would love nothing more to replace it with a cheapo lever style like my JSW had.. Just not sure about the wires that appear to go to it. I could ask the dealer at my first service but I dont know if I can wait that long!
IXLR8
Cushing, ME
12 Passat Platinum Gray, 02 Golf Black, 01 Jetta Black
I haven't figured out how to change out the auto dimming mirror, but I am sure with you on this one. 90% of my driving is at night/early morning and I hate the auto dimming mirror. Presently I am looking at putting a LED in front of the sensor to keep the mirror dimmed all the time.
APT
Metro Detroit
2012 Passat SEL
There is a switch to disable the dimming functionality.
15% tint on my rear window pretty much negates any need for auto dimming the review mirror.
Tdi Noobie
Waterford Michigan
Where is the switch to disable it? Not sure that is the best way, since it dosent have that manual switch to flip it.
Like you IXLR8.. Dawn/dusk driving and it never works.. Next time I am at the dealer I will ask if they can swap it.. Cant be that hard.
Glad it works for you Mr. Furious. I hate not having control. Sensitive eyes I guess. Wait til I cant turn the traction control off trying to get out of my driveway in 10 inches of snow. :)
APT
Metro Detroit
2012 Passat SEL
There is a button on the bottom of the mirror to turn the auto dimming feature on and off. Not quite the same as the manual switch as dimming off means it is not dimmed.
dubStrom
Kansas City Missouri
2003 A4 Jetta (sold), 2010 JSW (sold), 2013 Passat 6MT traded for 2014 JSW with 6MT-TOTALED in November 2016, 2003 ALH 5MT conversion (sold), wheezing 2015 GSW/DSG and a new 2021 Tacoma Access Cab 4x4 p'up
Raise the mirror a little, so that if you lift your head you get a full view, but head normal, only about 35-40% view. This prevents direct reflection and keeps it available. Try it. So far it is excellent for me.
Springfield, VA
I don't have this problem because the car has tint, although that creates its own issues with night time visibility.
Tdi Noobie
Waterford Michigan
Ive done the angle up thing dubstorm.. Works ok. I am still going to look for the manual one. They work better than the auto one when the auto on is dimmed in my opinion..
Tint, that will be done sometime.. Need to find a good tinting place in the mitten.
ng3
Newmarket, Ontario
2012 Passat TDI & Jetta TDI
The Canadian base model comes with the simple lever mirror, maybe check with a dealer if it can be ordered? Let me know if you need a part #.
Springfield, VA
You'll need to make sure that the manual mirror will hook up to the mirror mount in your car. It may be different than the S model if your car has a rain sensor.
ng3
Newmarket, Ontario
Mine's a Trendline+ TDI, not sure what trim it matches to in the US but it has the light/rain sensor, so I think the only problem would be if the ball the mirror mounts to is of a different size...
PassatDriver
Michigan
2012 Passat SE 6MT
I cant't stand the auto dimming mirror either, it is too slow to react and the glare is bad. I put a piece of tape over the sensor that points out the windshield and that seems to keep it dimmed more often. However, I heard that you can program the wipers to work on rain sensor (TDI SE did not come enabled from factory) and I think covering THAT sensor may negate that upgrade. Dealer tested the dimming function and said it works the way it is supposed to.
Springfield, VA
The wipers do not use the light sensor on the back of the mirror. Instead, they use the array inside where the mirror mounts to the windshield.
Fix_Until_Broke
Menomonee Falls, Wisconsin, USA
03 Jetta, 03 TT TDI
Has anyone looked further into this?
I'm in agreement that the auto dimming rearview mirror is generally useless. Goes from bright white to bright green and only when it's dark (because obviously, there are only bright things in the night time, it's impossible to have bright things in the day time, WHEN THE SUN IS OUT! :rolleyes:).
vw_norm
Gone, but not forgotten.
Hawaii
2012 NMS TDI SEL Platinum Gray w/moonrock
mine works fine. There is a +12V signal that goes to the mirror when you put the car in reverse to undim it in order to make it clear for you to see behind. The little green LED in the front of the mirror should be lit to indicate that the mirror can dim.
CallMeColt
Texas
2012 Passat SE
I'm interested in changing my mirror to a DVR mirror. Since this mirror has a non-standard mount due the rain sensor, it complicats things. Does anyone by chance have a measurement of the OEM ball mount? I wondering if it's a standard size & the DVR mirror can be pushed on it.
I also found the Rostra adapter for the NMS but it's unclear if if goes over the rain sensor.
https://12voltsexpert.com/product/rostra-250-8606-mirror-adapter-mount-volkswagen/
Skimax
White mts, NH
97 B4 variant(retired at 330K), 2000 B5 1.8T passat retired, 2013 SE (buyback5/17) 2015 SEL, 2015 E-Golf SEL sold March 2019, 2018 Volt LT and a 2007 PRHT MX5 for fun
I agree this is the worst feature of the car. Are we getting so lazy we can't reach up and flip a lever? Fortunately I don't have to drive at night that often any more.
