Beacher
This is just a quick post to see if I can get a consensus on the following symptom. My automatic 2004 automatic PD has been giving us some problems recently and my wife is now afraid to take the car out on her own.
The recurring issue is that we start the car, get about a block or two away, get to the first or second stop sign and the car dies. On restart, the engine turns over fine so the battery is fine. On both occasions that this happened, after turning the engine for a battery punishing long time, it does finally start again. Once running, I've been able to get it going again by using the tiptronic function and keeping the revs hi until it's properly warmed up. After that, it seems to run just fine. The engine does not throw a CEL so my suspicion is that it is a fuel issue. I'm going to replace the fuel filter myself today to try ruling things out one at a time, but from my initial investigation on the site - it sounds like it might be the lift pump.
So my questions for anyone who might know:
- Does it sound like I'm on the right track? - ie the lift pump?
- Is there an easy way to determine if the lift pump is shot?
- If it is the lift pump, is it something easy to replace yourself?
- If it is easy to replace yourself, where's the best place to order one, and how much would be a good price?
Thanks in advance for any input on this one.
Beacher
Beacher
