environmentalteach
When I try to start my car, it has to crank a few times before it will run. This is especially noticable when car is warm.
What does this mean.
__. Have someone else start your car and look at the clear fuel line (I hope you have one of those most TDI's do). Do you see a lot of bubbles, still before cranking starts and then moving?environmentalteach said:When I try to start my car, it has to crank a few times before it will run. This is especially noticable when car is warm.
Does that provide additional amperage to overcome the voltage drop caused by high resistance?Bob_Fout said:Would hooking it up to battery charger on "start" mode tell if it's the starter or not?
Might provide 20A or 30A, not sure thoughwhitedog said:Does that provide additional amperage to overcome the voltage drop caused by high resistance?
