highmileage
- Joined
- Sep 17, 2013
- Location
- new jersey
- TDI
- 2005 passat bhw tdi (presently), 2001 jetta alh tdi (previously), 1998 jetta ahu tdi (previously)
Just before egr cooler noticibly failed I heard a change in behind dash water sounds. (Position and intensity increase) Made me think of heater core. Then got white smoke and antifreeze loss. Changed egr cooler and no more antifreeze loss or smoke. However, still have sloshing and no heat. What is likelihood of cooler and core failing at same time? Thinking air in system from cooler failing. Tried bleeding at heater core hose. Not much change. Both heater core hoses are hot. Any suggestions? Thanks in advance.
