paramedick
TDIClub Enthusiast, Vendor
Came to me on a flatbed. History of gradually more difficult starts until it eventually would not start. 84K miles
Found that it cranks at proper speed, and fuel does come out of loosened injector lines. Pump did have some air in it. Owner changed the filter prior to sending it to me. Did not change the T O-rings (done now). Fuel examined, and found to be dark brown. Reported to be homebrewed biodiesel.
Pump purged of all BioD, and fuel lines cleaned. Interinjector lines replaced because horrible. System reprimed with dieselpurge and injector lines bled. Fuel supply isolated, and DP in it's place. Engine cranks and tries to start, but fails.
Timing belt performed before attempting to start, so all marks line up. IP sprocket centered. Shutoff valve jumpered without effect. Tapped the pressure relief collar back in place as it had backed out about halfway. Antishudder valve open. Intake manifold is not clogged. Glowplug light illuminated when key turned, so relay 109 not suspected.
Compression is 440 all cylinders.
Main code is a "quantity adjuster upper limit", besides a glowplug code.
My diagnosis is a failed injector pump.
Anyone with anything I have forgotten, please chime in. All suggestions welcome before I have this gentleman's IP rebuilt.
Bruce
Bruce
