bms707
- Joined
- May 11, 2014
- Location
- way way nor cal
- TDI
- '84 yota 4x4 ALH TDI, '03 Jetta wagon(soon to be 6speed)
Some Updates:
TPS (gas pedal) mounted, i just hacked up the factory vw bracket a little bit, some bolts/spacers from ace and viola..
It sits a little bit further right than the original toyota pedal, but it not enough to bug me
VW raditor mounted, made some small steel brackets on the drivers side, passenger just bolts staight to the core support
Front view, only 2/3 of the core will be open to the wind, is this ok? Someone chime in on this. Plenty of room for an inter cooler too, sweet!
Battery mounted nice and solid with VW bracket, even get to use the vw P/S reservoir, piece o cake!
Dash torn apart, running the engine/ pedal wiring. I'm mounting the ecu in the factory toyota location. The VW fusebox will go behind the glovebox for easy access, as well as relays 109 & 180. Not having A/C really frees up room in that particular area..
