towforce
I use the phrase "The" Gasket because apparently there is the possibility I might have installed a gasket that may not be compatible with my valve cover.
At 375,000 km's, in 2015 I decided to do a cam inspection. I ordered a new valve cover gasket. I honestly have no idea if there was any sort of warning about compatibility issues for the one I ordered from IDP but if you try to order one now there is warning about compatibility and fit on a BEW valve cover.
Since the inspection, there has been an untraceable minor oil sweat off of the top rear of the head... my bet is the VC gasket is the culprit.
My question, if the gasket is not compatible would it have fit and had only a minor leak or would it have been obvious from the beginning?
After doing a bit of research, looks like if it the culprit and the gasket is not the compatible version, it will mean a new valve cover from VW.... I may try some RTV....
Like I said, its just a minor sweat, usually wipe down the block and accumulations between oil changes.
Martin
Martin
