Here is why I don't mess with the CR engines very much...
One of my customers decsribed the CR cylinder head as 'dainty'. That's how you want to describe your Diesel engine..Dainty.
The issues we have seen after attempts at big power... The rocker/ roller and contact point to the valve stems is weak. The fulcrum point for the rocker roller would have to be redesigned in order to make use of a taller rise cam. The roller needle bearings flatten out under extreme load, particularly on the exhaust side.
One recent CBEA cylinder head we reworked, almost all of the components for the exhaust side were trashed in an engine supposedly modded to 250 hp and sold with 6,000 km on it. None of the exhaust valves were turning because the rocker had extreme wear marks in the valve contact end. The designed method for the turning the valves was worn off of the rocker. Most of the rollers were not spinning and almost all of the hydraulic plungers were locked hard in place.
All this happened very rapidly to the engine. I think there are better platforms for big builds than the VW CR. This engine and a couple of other CR engines have given me little faith in the longevity for building the CR for large power. I am sure there are those who will dispute my findings.
We were considering a cam design, but the complications and overcoming the multiple issues along with the continuing uncertainty for the future of American common rail engines caused us to cease engineering efforts.
Porting is quite the problem. As the engine is, the porting is down right ugly. The complication is that any increase in flow volume has a trouble with upsetting the forced swirl built into the port design. The intake ports vary in size to impell the swirl. Without a very complicated setup that would demonstrate proper swirl chamber effect, the only thing one could do is a wild guess.
Since we are busy enough with other projects, we will leave this one to those with more confidence for success.
