yeahkkyle
I know this has been probably been covered numerous times before but I've been trying to trace down a low MPG issue. 2003 ALH 5 speed bone stock Jetta. I got the car 2 years ago with 152k miles on it which the previous owner just replaced the timing belt, tensioner, water pump, egr valve and cleaned the intake. I had a friend with vag-com check timing last year and was spot on. I always consistently got around anywhere from 48-53mpg depending how many highway miles I drove, mainly back roads. Last fall around 180k miles I started getting an over-boost code so I bought a kit from IDparts and replaced the MAF, N75 valve, waste gate actuator and all vacuum lines with silicone hoses from another site. Turned out to be the waste gate actuator diaphragm was dried out. After replacement car ran great and could actually hear the turbo whistle again.
Car now has 185k on it but around 183k miles I noticed a loss in power, a slight haze of smoke during take off, slightly rougher startup when weather was cold with slight white smoke and also a loss in mpg, last 4 tanks have only been ~37mpg and two of those were 90% highway doing 60-65mph where before I would avg 52-53 doing that speed. I haven't changed my driving style at all. I swapped MAF sensors with my old but good one and no change, just to try. I unplugged MAF and it made the car more sluggish. I also disconnected the waste gate actuator and it feels like it moves freely, full movement too. Removed the egr valve and other than a slight film the intake and all looks to be in good shape. I replaced the air filter and fuel filter ~700 miles ago just to be safe as well.
I currently live 5 hrs from said friend who has vag-com as I'm in the navy so I don't have access anymore. Anywhere else to start looking other than hooking the car up and seeing what is going on? Maybe injectors starting to get wore out? It was kinda like a instant change in the loss of power, car was running fine and wife took the car and said it felt slower than normal. No CELs either. Thanks for any input or help.
