DPF Pressure Sensor P2456 Error Code
mjhandy
Kitchener, Ontario
2009 Touareg TDI
I've posted about this on Club Touareg, but I thought i'd try here too. This came up last night. Joy.
009302 - Diesel Particulate Filter; Differential Pressure Sensor
P2456 - 002 - Intermittent - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 186138 km
Time Indication: 0
Date: 2016.08.22
Time: 17:41:27
Freeze Frame:
RPM: 735 /min
Speed: 0.0 km/h
Pressure: 181 mbar
Temperature: 139.5°C
Temperature: -277.3°C
Bin. Bits: 00000001
(no units): 61.1
Sprocket
Sprockette's hubby
MI
2014 Jeep Grand Cherokee Summit Eco Diesel, 2005 Passat Silverstone Grey, 1996 Passat Storm Grey
There was a recall on this a couple of years ago along with a software update for the ECU. I'm wondering if yours was replaced in the past and the part went bad OR if yours was still the original. If it was the original, it should've been covered.
mjhandy
Kitchener, Ontario
2009 Touareg TDI
Not sure. I do know that since it was replaced I got a bunch of DPF errors. So either the sensor is now reporting correctly, or something worse. I'm just trying to figure out how to correctly read the soot levels.
Sprocket
Sprockette's hubby
MI
Do you mind posting your VCDS scan also showing your ECU software version?
It should be similar to this in VCDS:
Component and/or Version: 3.0TDI EDC17G004AG 0100
mjhandy
Kitchener, Ontario
2009 Touareg TDI
Sure, here's the scan. Ignore the other issues, i'm working through them.
Wednesday,24,August,2016,18:41:59:35547
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
Dealer/Shop Name: Mark Handy
VIN: WVGFM77L39D029775 License Plate: TOUAREG
Mileage: 186500km-115885mi Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2E 37 3C 46 47 55 56 65
68 69 6C 6D 6E 76 77
VIN: WVGFM77L39D029775 Mileage: 186500km-115885miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CAT) Labels: 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 K HW: 7L0 907 401 K
Component: 3.0TDI EDC17A100AG 0040
Revision: 33H01--- Serial number: VWX3Z0H6817312
Coding: 0421002A590F0268
Shop #: WSC 20995 444 87881
VCID: 336532B551BFB3DA6D-5106
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 HN HW: 09D 927 750 HN
Component: AL 750 6A 1473
Revision: 00H75000 Serial number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 0109A87D5B83D14AAF-5140
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0006402
VCID: 46837B61352D3672DA-8012
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 C HW: 7L0 909 137 C
Component: 2G Kessy 6850
Revision: 00H22071 Serial number: VWX3Z0H6817312
Coding: 0147688
VCID: 336532B556BFB3DA6D-8066
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 212
Time Indication: 0
Date: 2016.08.24
Time: 10:32:44
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AK
Component: CLIMAtronic R/L 4337
Coding: 0023030
VCID: 79F9C09D3453898AE7-802C
1 Fault Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - - - Intermittent
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2002
Revision: -0004--- Serial number: --------------
Coding: 220008002F00BC000000000000000000
Shop #: WSC 40399 444 30859
VCID: 000FAD795789D842A0-8054
Address 13: Auto Dist. Reg Labels: None
Part No SW: 7L6 907 567 A HW: 7L6 907 567 A
Component: AC201 RDW 1 031 0382
Revision: 00031000 Serial number: 00000000663939
Coding: 0010000
Shop #: WSC 00000 000 00000
VCID: 3C7719897BE17CA2BC-8068
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234__3N VW8T 0250
Revision: 92012025 Serial number: 0039P006RM06
Coding: 0013134
VCID: 7AFBDF9131558292EE-802E
Subsystem 1 - Part No: 7L0 959 339 F
Component: BF-Gewichtsens. 007 0010
Subsystem 2 - Serial number: 3RFNM
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 G
Component: J527 3601
Coding: 0011021
VCID: 43856275061F035AFD-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 990 P HW: 7L6 920 990 P
Component: J285 KOMBI-INST. 9633
Revision: KHH06V41
Coding: 0007201
Shop #: WSC 93237 999 14764
VCID: 46837B61312D3672DA-8012
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 990 P
Component: J533 GW-K-CAN TP20 9633
Coding: F7E6F7DBCB846002
VCID: 70EFFDB96329C8C250-8024
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667299104
Coding: 010000
VCID: 2643DBE1516DD672FA-8072
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 684 D HW: 7L6 035 684 B
Component: RNS-MID H01 1142
Revision: AB001001 Serial number: VWZ6Z7H9308065
Coding: 000500000100001600
VCID: 377D06A586C75FFA51-8062
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7L6 907 566 B HW: 7L6 907 566 A
Component: J0769_SWA_MasterH10 0070
Revision: 00H10000 Serial number: 6PZ 009 014-01
Coding: 0000051
Subsystem 1 - Part No: 7L6 907 568 B
Component: J0770_SWA_Slave_H08 0070
Subsystem 2 - Serial number: 6PZ 009 014-21
Subsystem 3 - Serial number: 3F04.11.0800H0800000010039ÿ
Subsystem 4 - Serial number: 010039ÿ
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 4M HSG 0601
Coding: 0000085
VCID: 408F6D7910091842E0-4B00
Subsystem 1 - Part No: 7L0 959 701 P
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 P
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 466 C HW: 7L6 035 466 C
Component: DSP 10 Kanal 0020
Revision: 00H05001 Serial number: 75835000526004
VCID: 346731A957B1B4E274-8060
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 1290371
VCID: 3B751A957EEF7B9AB5-806E
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l S004
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r S004
Coding: 00000019
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 65: Tire Pressure Labels: 7L6-907-273.lbl
Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
Component: J0502 RDK 0006
Revision: 00004006 Serial number: 00000700013648
Coding: 0040008D8D0000000000000000
VCID: 3A7B1F9171D54292AE-806E
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 3979009D70D3498AA7-806C
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 041108 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 L HW: 7L0 907 383 L
Component: J345 Anhaenger 0080
Revision: 4A014001 Serial number: 00000109175632
Coding: 0000002
VCID: 3D71148D60FB75AA8B-8068
1 Fault Found:
00532 - Supply Voltage B+
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 186321 km
Time Indication: 0
Date: 2016.08.24
Time: 10:32:37
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 B HW: 7L6 907 441 B
Component: J772__Rearview 0033
Revision: 00H13000 Serial number: PA8 J890314
Coding: 0010001
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 189
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------042345
Coding: 0122110
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No SW: 7L6 919 044 AD HW: 7L6 919 044 AD
Component: J702 Dachdisplay 0401
Revision: --30006S Serial number: 00000000086639
VCID: 79F9C09D3053898AE7-802C
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
VCID: 3979009D74D3498AA7-806C
1 Fault Found:
00435 - Front Right Inner Parking Aid Sensor (G333)
006 - Short to Plus - Intermittent
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 96P HW: KTC 364 96P
Component: SWP:3.11.8 H24 0185
Revision: 00000000 Serial number: 00000000000000
Shop #: WSC 21977 142 74100
VCID: 3E73138169FD6EB292-806A
End-------------------------(Elapsed Time: 04:14)--------------------------
Sprocket
Sprockette's hubby
MI
From the looks of your VCDS scan, it does not look like the Emissions Service Action 23M1 was ever performed on your Touareg.
Your software version = Component: 3.0TDI EDC17A100AG 0040
The update would've changed your last 4 digits to 0100
Please see attached file showing the TSB and specifically page 7 where it shows what the new software is after the update.
Hope this all makes sense.
You should've received a new pressure sensor as well as part of this service action at no charge.
I'd call your dealer or VW and get them to take care of this for you.
mjhandy
Kitchener, Ontario
2009 Touareg TDI
Damn. Thanks. And a new sensor without the update could be the cause of the other issues I've been having.
Cheers.
mjhandy
Kitchener, Ontario
2009 Touareg TDI
There was a TSB done for a differential sensor, which at the time I thought was for the centre or rear differential, but only the sensor was replaced. They couldn't connect to upgrade the ECU. So I though nothing of it and time passes. So, I called the dealer, and their records say this was done, but it looks like it wasn't.
Sprocket
Sprockette's hubby
MI
Yikes, this may turn out to be a fun experience with your dealer and trying to get them to do the update. Good luck, I wish you the best ;)
mjhandy
Kitchener, Ontario
2009 Touareg TDI
So the dealer managed to get the TSB done. I'm also getting the hood latch replaced so i'll have to fight for money back because of the TDB issue.
Yeah dealers.
mjhandy
Kitchener, Ontario
2009 Touareg TDI
Ok, and update here. This is my fault for not following up, but I had all the same issues again. I came back to this thread, went back to the service action posted by Sprocett, rescanned, and yeah no match. The dealer had said they had done this, as I had asked on two separate occasions.
They flashed the ECU, and the version is now 110, not 100. Not sure what the difference is but so far so good. I have done a scan or looked at Block 108 yet.
Sprocket
Sprockette's hubby
MI
Good to hear that you're updated to an even new ECU software version. I'm curious as to what the difference is.
Curious, are you planning on selling your Touareg back to VW?
mjhandy
Kitchener, Ontario
2009 Touareg TDI
Then can have it when I'm dead :)
I like the Treg too much, and as my work commute is going from over 800KM (550 miles) a week to less then 200, it'll be cheaper to maintain
mjhandy
Kitchener, Ontario
2009 Touareg TDI
I have noticed I smell more ammonia from the back end, so I suspect it's using more AdBlue.
m B Passat B8 2019
woen
After change timing belt I had P2456 Error fault code. The pipes were exchanged between them!I discovered this only after I changed two sensors thinking they were defective (Passat 1,6 TDI 2019)
m B Passat B8 2019
woen
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 186138 km
Time Indication: 0
Date: 2016.08.22
Time: 17:41:27
Freeze Frame:
RPM: 735 /min
Speed: 0.0 km/h
Pressure: 181 mbar
Bin. Bits: 00000001
(no units): 61.1
