Jason H.
I am getting codes p0266, 0269, 0263, 0272 all at the same time( no check engine light, only flashing glow plugs light)
No hard starts, idles perfect, runs perfect, no black smoke, no turbo lag.. nothing.. still 45-50mpg cruising on Highway and 36-40mpg city.
On my obd11 (knockoff vagcom if you will) all injectors at idle are with in .1 of each other when the range allows for -2.0 to +2.0
And here is another kicker.. it's only throws the codes on initial start up. I can clear them after and they do not return until I restart again.
I've confirmed that the glowplugs are good although I'm pretty sure if they were bad I'd be getting a correctly associated code. Just changed fuel filter as well.
Any ideas would be great...
189k+ miles on it.
189k+ miles on it.
