elDGM
Hello all! My 2006 Jetta TDI shut off on me multiple times while driving. Had to get it towed back to my house. The engine cuts off and also the instrument cluster goes dead with the exception of the screen where the time and mileage are displayed. The first time I had the AC on and the AC blower continued running. After a few minutes when I move the key to the on position the instrument cluster lights come on and I am able to start the car again, but then dies after a few minutes.. The charging system is working fine. I replaced the battery as it turned out to have a defective cell, but still the problem persists. I have been unable to find a problem with any of the battery terminals, grounds, loose wires, loose connectors etc. I did find a blown fuse in position SC25 - Vehicle electrical system control module (J519). I replaced it but still problem persisted. I have run many VCDS scans. After a week of trying to find a cause or loose wire etc. the car runs fine today. I am stumped! Below I will post the last problematic scan and then the scan after the car started working and I cleared all codes. Could this be related to the ignition lock cylinder? Any and all help appreciated greatly!
Saturday,05,October,2013,12:10:38:28501
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: 3VWST71K66M784325 License Plate:
Mileage: 221760km-137795mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71K66M784325 Mileage: 221760km/137795miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H02--- Serial number: VWZ7Z0F3428759
Coding: 0050071
Shop #: WSC 00066 000 00000
VCID: 63EB67BFA23AED06E91-8036
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71C71DF768C64F966BD-8024
1 Fault Found:
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 69F775974016B75623D-803C
2 Faults Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000275467
Coding: 14018E234004150000140000001400000008730B5C
Shop #: WSC 25155 444 59542
VCID: 2A75CA9B85907C4EEA7-807F
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 25155
6 Faults Found:
02092 - Enabling Heated Seat
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.95 V
ON
ON
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 109
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
02403 - Terminal 15 for Interior
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.95 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.00 V
ON
ON
OFF
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.90 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7F5044674
VCID: 2B7BCF9F8A6A6546111-807E
2 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 197480 km
Time Indication: 0
Date: 2000.00.00
Time: 14:06:42
02788 - Internal Communications Error
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 00:20:10
Freeze Frame:
Bin. Bits: 00000010
Bin. Bits: 00000000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD04TRFS
Coding: 0013113
VCID: 3957E5D77036C7D693D-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0E1C4A67P
Subsystem 3 - Serial number: 6342MSME0E1C710EL
Subsystem 4 - Serial number: 6351HSME0923584EC
Subsystem 5 - Serial number: 6361HSME09234B513
Subsystem 6 - Serial number: 63727SME0843006C-
Subsystem 7 - Serial number: 63827SME086C5E59K
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000021
VCID: 78D120D30BBC1EDEAC3-802D
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 953 D
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
VCID: 2C79CC838F64627E18B-8079
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001061091764
Coding: 3D3F0B60071002
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 364DEEEB412828AE7EF-8063
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 000 3305
Revision: 00H22000
VCID: 3753E3EF4622D1A6659-8062
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 01:00:22
Freeze Frame:
Voltage: 13.38 V
DU
Temperature: 33.0∞C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:02
Freeze Frame:
Battery Volts: 12.9 V
PD
Temperature: 29.0∞C
Count: 2
Steering Angle: 0.00∞
Count: 1
SteerAng n.Init
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74C914E317D47ABE80B-8021
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7F6009547
Coding: 0040400
VCID: 206128B3F3ACB61EB43-8075
1 Fault Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 12:59:17
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 3147DDF7A8460F962BD-8064
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245D2FBAD40348E527-8067
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D7FC187B47E6B760F5-8078
End ---------------------------------------------------------------------
After car started running successfully again today, I cleared out codes also changed adaptation settings to clear power steering control module fault that I had for a long time. This is the current VCDS scan.
Saturday,05,October,2013,14:15:10:28501
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Coding: 0050071
Revision: 00H13001
Coding: 0021122
Coding: 00063445
Shop #: WSC 25155
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 197480 km
Time Indication: 0
Date: 2000.00.00
Time: 14:06:42
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 150
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 01:19:48
Freeze Frame:
Bin. Bits: 00000010
Bin. Bits: 00000000
Coding: 0013113
Coding: 0000021
Coding: 0023203
Coding: 0001269
Revision: 00H22000
Component: KSG 0401
Coding: 0001269
Coding: 0040400
Coding: 0000144
Coding: 0000144
Coding: 0050071
Revision: 00H13001
Coding: 0021122
1 Fault Found:
2 Faults Found:
Coding: 00063445
Shop #: WSC 25155
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.95 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 109
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.95 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.00 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.90 V
ON
ON
OFF
OFF
OFF
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 197480 km
Time Indication: 0
Date: 2000.00.00
Time: 14:06:42
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 00:20:10
Freeze Frame:
Bin. Bits: 00000010
Bin. Bits: 00000000
Coding: 0013113
Coding: 0000021
1 Fault Found:
Coding: 0023203
Coding: 0001269
1 Fault Found:
Revision: 00H22000
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 01:00:22
Freeze Frame:
Voltage: 13.38 V
DU
Temperature: 33.0∞C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:02
Freeze Frame:
PD
Temperature: 29.0∞C
Count: 2
Count: 1
SteerAng n.Init
Component: KSG 0401
1 Fault Found:
Coding: 0001269
1 Fault Found:
Coding: 0040400
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 149
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 12:59:17
Coding: 0000144
1 Fault Found:
Coding: 0000144
1 Fault Found:
Coding: 0050071
Revision: 00H13001
Coding: 0021122
Coding: 00063445
Shop #: WSC 25155
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 214
Mileage: 197480 km
Time Indication: 0
Date: 2000.00.00
Time: 14:06:42
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 150
Mileage: 221763 km
Time Indication: 0
Date: 2000.00.00
Time: 01:19:48
Freeze Frame:
Bin. Bits: 00000010
Bin. Bits: 00000000
Coding: 0013113
Coding: 0000021
Coding: 0023203
Coding: 0001269
Revision: 00H22000
Component: KSG 0401
Coding: 0001269
Coding: 0040400
Coding: 0000144
Coding: 0000144
