Last year, some owners of 2012 reported issues. Time and weather will show if the 2013 still are afffected, but most likly they will.
Further proof that VWoA flat out lied to me in saying that the 2012 models have the revised design then...
Showed up at dealer before 8am today & was treated respectfully, even got apology. It was a power steering hose rubbing on the left hand (passenger) side rad fan. Fixed in a minute & on my way. Keeping my fingers crossed...Thanks loafing. This repair seems like a double edge sword. You get the repair done so no icing, but then sometimes the dealer screws other things up, damages the car, etc.....
I recall that it (hydrolock) happened to me after about 800km trip around freezing temp but not really cold.What were the conditions that were causing this again? Does it have to be below 32f outside air temperature? Damp outside or raining/snowing?
If you mean mimmick the air-to-water intercooler design of the 2012 Passat then yes, that will fix the problem. That is a really good idea, add a heater line inside the intercooler.just thinking out loud here......would adding a coolant heater aleviate this problem??
see my sig >Called the dealer, who offered to look at it, but said, "They're switching to winter blend right now" so "it's probably just a little water in the fuel".
Sorry for you didnt wait long enough.......Long-time lurker, first-time poster as I've had no real problem worth investigating with the car until today. Wish I'd read this thread before more thoroughly...
Drove to work in the rain at 53*F yesterday a.m., and then went out to the parking lot this a.m. after my shift and started the car w/no problem at 23*F. I then drove home and parked it in the garage at 60*F. Six hours later I tried to start it and it died.
So I tried again, and again, and, well, you know, until it sputtered to life. It ran rough for about a block and then cleared out. Called the dealer, who offered to look at it, but said, "They're switching to winter blend right now" so "it's probably just a little water in the fuel".
Then I read the "intercooler icing" threads here.
Have really enjoyed the car. Waited two years to buy to ensure VW had gotten it right.
Should've waited two more for a Passat, I guess.
http://www.myturbodiesel.com/forum/f7/cr-cold-weather-inspection-4197/how much condensation and ice build up are we talking here?
Just out of curiosity, how many miles/kms since your last service? My event took place about 8000km after last service (2/3 way to next service).Long-time lurker, first-time poster as I've had no real problem worth investigating with the car until today. Wish I'd read this thread before more thoroughly...
So, similar situation to my event. Hope you're in the queue for the cold weather IC kit... Other than that, my vehicle performed flawlessly before the modification, today in for the third time since, this time to chase out the warning lights gremlins (first the hood release was disconnected, second was cooling fan rubbing on power steering pipe). At least they are polite....I should also note that the couple of times I've driven the car since the episode, I've noticed a bizarre exhaust odor, whereas there was no exhaust odor previously. Also, my mileage that morning and since has been several mpg less than what I would have expected under the circumstances, after 26K of getting to know the car.
That might work. Perhaps a water/oil catch can like the ones BFI sells.ok, smack this idea down if you think it's crazy...but it hit me the other day.
LP EGR gasses are cooled. What I don't know is how cool they get. I haven't looked at the LP EGR line after the cooler, but could it be possible to install an air compressor water/oil separator in that line before the turbo? If the LP EGR is the source of much of the moisture, that could be an easy and inexpensive fix. The only concern I have is temp of the gasses. I would think flow through the filter should be ok.
Good idea? Completely bonkers? Thoughts?
With the IC icing coming back into season I'm sure glad I traded my golf for the passat . How long is this gonna go on befpre an official recall is in order .... How does vw keep avoiding recalls on these serious problems ?
