First- thanks Dan for that great AC trouble shooting guide but I have an issue that departs from the guide I'm hoping for some help .
First probelm- no AC Clutch engagement, 2nd problem - only one fan comes on when AC button engages.
What I found- Power to the AC clutch is bad and intermittent. I have seen 0 volts at the connector and I've seem 9.85v at the connector... never 12V. I found the clutch magnet is bad (open circuit) so I have a new one coming. I tried replacing the fan controller module- no change in behavior.
To be through, I followed the "no power at the clutch connector- 2B section). All fuses test good (verified power at both sides). BUT when I look for power at pins 5 & 8- I only have power on pin 8... nothing on pin 5. When I go to pin 2 on the high pressure switch, the wire color doesn't match the guide says not red blue? I believe the switch is working because when I unhook it, the single fan stops spinning but I'm not able to get 12v wen back probing the connector with it hooked up.
My wire diagram is from a 2004 and your guide was written for a 1999 ( i believe??) thoughts?
