oilhammer
I'd like to share some information to folks who are looking to take advantage of some of these 2009-16 bought back and fixed and now for sale cars that are popping up all over the country.
These are a great value, and the last of their kind. This is not at all meant to discourage anyone from purchasing one, and I myself wish I could justify buying one (or five) for my own fleet.
However, please do yourself a favor and look them over. Many of these cars have been sitting, often in areas that are not necessarily friendly to cars.
Here is some pics from one I had today, and while this is not the first one I have seen in here like this, it is probably one of the worst:
The fuel filter screws are broken, I tried two, they both immediately snapped off. It'll need a totally new fuel filter ASSEMBLY.
Several of the air filter screws also broke, they literally stuck inside the plastic and rotted away, and it needs a whole new air cleaner ASSEMBLY.
The tires "looked" OK tread wise, but upon further inspection, they are dryrotted, and are from 2014, and have flat spots on them. It will need a new set of TIRES.
Rear subframe bolt, badly rusted, as are all the brakes... and really in order to make the car stop correctly, it will need all new BRAKES, including possibly rear calipers and cables, as the parking brake mechanism is all stuck.
Except for the new lean NOx trap, EGR tube, and exhaust flap, which are all new from the 'fix', the EXHAUST SYSTEM looks like it will fall to pieces if you stare at it hard enough.
Every single nut, screw, bolt, clamp, clip, casting, flange, etc. that is made of metal is either badly corroded or rusted.
On top of that, the cabin filter was PACKED with debris, some of it from critters, the oil service indicator was reset, but the oil clearly had NOT been changed, as the drain plug was full of rust, there were dust marks over the top of the filter cap, and it had some collapsed no-name filter in it.
Literally all this car got was a new battery plopped in it, the 'fix' applied, and it was shoved out on the for sale lot. This is a 2012 sedan with only 62k miles, and Carfax shows that the car was essentially parked right when Dieselgate exploded, and has been sitting somewhere that clearly had high humidity ever since.
So please, do yourself a favor and look it over closely. This car looks fine from the top. Engine starts, sounds, and runs OK. But the underneath is what is going to be the real indicator. This car all said and done is going to need a couple thousand dollars thrown at it to get it really in reasonably good useable shape, and it still is going to likely be plagued with problematic fasteners down the road.
Now some of you in the rust belt may see this to be more of the norm, and I feel sorry for you guys. But not all of us have this problem, and also keep in mind the history of these cars, as they have been moved all about the country. And I suspect very little if any real valuation changes happen due to details like I am presenting. So a car that was from Texas and sat in Oklahoma for three years may be a much better car to buy than one that is from Michigan and sat in Ohio for three years, despite being the same color, equipment, and comparable mileage.
