HI,
FWIW I am running Hankook Kinergy tires 205 75 R15 ... suspension in front is Koni special active with Lesjofors VR6 springs (not sure if that amounts to lift or not .... I took measurements to fender well before and after .... Ill have to see if I can find them).
Only minor rub full lock in reverse ....Maybe some forward but not sure ... I don't cycle suspension much (no big bumps etc) so not sure if they rub full stroke of suspension).
I really wanted 215 or 225 75 15 for making a higher effective gear ratio for cruising and increasing ground clearance... 205 / 75/15 does help my fuel mileage and increases ground clearance which is good. .... maybe somebody can go big with little or no lift?
I am having 1" lift spacers installed this weekend to level out the car (reduce forward rake) ... maybe better aero ? Also to get back the ground clearance I lost when installing the metal skid plate (evolution).
I'm not sure the lift will reduce full lock or nearly full lock steering rub ( mainly on the pass side tire against the intercooler piping) since that is pobably the job of offset and wheel spacers?
Anyways, interesting thread .... hope to learn alot from this ...
Andrew
PS - It slipped my mind but while installing the 1" spacer for lift , I was also having harder rubber form 034 installed as well ( I think its called strut busging?) .... maybe that won't crush as much keeping ride height in front up higher under load or at rest ? (mainly did it to stiffen up steering response and feel tho).
Loaded with weight (about 600 lbs as far forward towards the front seats and biased to the driver side a bit as possible) and front passenger , the right rear tire will rub ( luckily did not rub through) on the plastic fender well "bulge" on bumps ( I assume this bump if for the gas tank filler tube but have not pulled the liner to see what is behind it ... If possible I may heat gun and flatten the bump so it won't rub if I haul heavy).
