You do know modding a BEW motor is not as easy as the ALH, right? Sounds like you've already done some stuff to it and now are dealing with CEL's. While I did the EGR delete on my ALH I also did not get a CEL because I already had RC tuning.ig109 said:I thought it would.. I just dont know what to do.. I am supposed to go on Vacation in this car on July 20th and i dont want to have to do this all again.. Id like to find a manifold and get this all done..
You can turn the EGR down with Vag-com (still will get CEL in most cases if EGR is removed) but that isn't the same as EGR delete via a tune. And for the mods you are going to do a tune is necessary to make full use of them - until then it's more of an eye candy situation.ig109 said:I am actually in the process of doing the mods now.. I have a spare vehicle for me to drive and just let the wife drive the truck.. so it will not hurt for me to be without the Jetta for a while, just have to get it all back together so i can see what i need to do.. any idea if i could take care of any of this with the Vag com system? I understand that you can do some kind of off road no egr change with the vag com is that correct or am i just reading all of this wrong..
