To continue, if the belt fits tight, it's right. Don't worry about it. The wider belt for the 1.9 and 2.0 PD's is universal for all single overhead cam PD motors. Less of an interchange issue than some cars.
Although the cam sprocket can be 'put on wrong', the only thing you need to worry about is to get the 3 bolts as close to thet middle of the adjustment as you can. For convenience, we put the large 'crown hole' UP as that is a reference for TDC.
Once you get the belt on and the cam sprocket aligned in the center of the adjustment for the cam sprocket, hand-tighten the cam sprocket screws. Set the spring tension on the timing belt tensioner, aligning the arrow and nock and tighten the tensioner bolt about 20-24 ft lbs. About 1/4 turn after all the slack is pulled up on the bolt.
Now, with the crank lock in position and the cam lock positioned, use a socket on the 18mm center bolt for the cam pulley and 'feel' the cam lock pin. When the pulley is just right, and the cam pin will slide out without resistance, tighten the cam sprocket pulley bolts one-at-a-time.
That's all there is to setting static timing. The trick comes with setting Engine Module/ Measurements/ Block 04/ torsion value for best economy.
