So I heard that you can install a 12mm hydraulic head on a 12mm michanical block. I was seeing how this would be done sense there is a oil return hole on the hydraulic head. The guy mentioned to install a plug in the extra oil retune hole is then your ok to used that head on machanical block. So I'm guess I'm asking if anyone has done this or heard of it.
