tcris3
Hi, i just got back from a roadtrip(600miles or so) and noticed the entire underside of the car covered in motor oil. i checked the dip stick and it is not even reading...added a quart and still no read. the car seemed to be running fine but i dont really know how long it was running with out oil. after adding more oil i started the engine and crawled under to see where its leaking...its dripping off a bolt on the underside of the turbo, it looks like an oil feed or return line and it bolts up on the underside of the turbo. I took a picture to make explainning it easier but i dont know how to put it on here(im not real computer literate) but i can email it to you if needed. Also I am very concerned that when the car was running to find the leak i hear no turbo noise at all...with my exhaust it is normally quite noticable, even if i rev it no turbo noise. what do you guys think? what is the first step here???
