1/2 drive enough oomph?
Dadwagon
Canton, ct
2004 Jetta Wagon
For the 19 MM crank all, will I be able to get the required torque setting (88 pounds +90°) with half inch drive?
My current toolbox for that kind of job Is 20 inch driver with a cheater pipe in a Stanley 12 point standard socket
Wondering if I should go to Harbor freight and grab three-quarter inch drive stop?
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
I think it depends on the quality of the tool...
I broke a 1/2" breaker bar doing this same job, but it was some made in china crap. It broke right where the pin goes into the swivel head. Smashed my knuckles into the ground and damn near my forehead too.
Mongler98
COLORADO (SE of Denver)
buy $3 socket, weld it to a par of iron or black pipe or whatever. I saw someone use a cheep 3/8 drive torque wrench to get it to 90ftlbs, then he bolted the socket to a 2x4 framing lumber and cranked it down, this was on a POS Chevy s10. IT WORKED i ended up getting him a six pack on our bet that it would not work. My Hard drive got wiped back in 2006 so i dont have them pictures i took with my 1magapixle flip phone in the dark but its a good story.
Tdijarhead
Lawrenceville PA
Get some quality tools Mac , snap on and throw the Chinese junk in the garbage.
Mongler98
not this time troll.
those tools are overpriced and aside from a few times when it was worth it for that one tool that you had to have, pointless.
cobalt and crafsman (well at least the old ones for craftsman)
at the price you have spent on mac or scamon tools, you could replace a broken HF tool 20 times over but you dont have to because that cheep Chinese crap has lifetime replacement on it as well.
Husky is actually fairly good.
You think your scamon tools are not cheep chineseium! lol.
I stocked my garage with a 5x10 foot tool cabinet from a no name with bearing rollers, and got all my sockets and tools, just about everything under the sun and more, and im only out about $6K in total. I have worked on countless Porsches, VW, Lexus, you name it, and never had much more than the a few tools brake like a 1/2" breaker bar. Use the right tool for the right application and dont ask too much of the tool your using it for, otherwise get a better tool or bigger tool when needed only.
I bet you are the guy who purchased a tap and die set all at once, well i have all the ones ill ever need and i got them all one at a time and still spend 1/16 the price of a snapon tap and die set.
Aside from school debt, tool financing is a HUGE scam for mechanics.
Go troll somewhere else.
Tdijarhead
Lawrenceville PA
Troll really?
If you’re going to use tools everyday then buying quality is in your best interest. The Mac tools I have acquired are the common hand tools that you use almost every time you open your toolbox.I keep watch on eBay and other places you can actually pick up some good deals and I have done so, as I do not have direct access to one of those traveling tool truck emporiums.
I have some craftsman inherited from my Dad, I started to add to that with Kobalt, then they went offshore so I stopped that and started with mostly Mac.
It’s throwing out comments like “troll” that irritate others and don’t really strengthen your point.
To think I was deliberately cutting you some slack as others took your opinions to the woodshed.
By the way I don’t have a set of tap and dies, I do have my brothers chinese set on my bench and it is complete garbage. I already ruined two taps and have yet to complete the job I need to do.
Hyde7278
Central Mich
2001 Golf GL
Buying quality tools (snap on, Mac, matco, SK) at pawn shops and eBay is the best way to go. The cheap tool only cost you more in the long run.
If all you ever do is oil changes then go cheap but if you use them more then a few times it's worth getting quality.
I've bought a few 1/2 breaker bars and 24" 80t snap on ratchets for well under a $100. If you go with the older 36t ratchets (24") you can find them for closer to $50. Even a HF one will cost you $30+.
Mongler98
a socket bolted to a 2x4 can do the trick some times
Relax, i get called a troll sometimes too, not trying to bust your balls!
I do buy a few quality tools when i need them or one craps out on me, like a air impact or taps.
I had to buy a quality transmission jack as mine crapped out on me, old 1940's beast. So glad i did, but i still got it at HF and its done everything i have ever asked it to do and much more.
This thread is now about tools.
[486]
MN
02 golf ALH
I use the impact to get the 90 degrees, who cares how it's turned that last little bit so long as the bolt gets the stretch.
it does take my big #5 spline drive impact though
fouillard13
Pincher Creek, AB
03 Jetta TDI Standard
I've used mastercraft and other junk my whole life. My new job has about 30 fully tooled up snap on tool boxes with snap on tools. The quality is night and day. I’m scared to see the price tags though. Amazing tools. Very nic stuff.
Ol'Rattler
PNA
2006 BRM Jetta
In case anyone is interested, Craftsman tools are now Chinese made garbage. If you have older American made Craftsmen tools, hold on to them and just throw them away if they ever break because what Sears will warranty them with are Chinese garbage.
Yep, and Sears just announced they are lawyering up for bankruptcy.
I gave the OP in his other thread about the same topic ( :rolleyes: ) a couple numbers for the proper SSTs, evidently he is not interested. And those tools are not even *that* expensive (but do require a quality 1/2 drive breaker bar and 12 point 19mm socket).
Good tools (Snap-On, Mac, Cornwell, etc.) are worth every penny. If you have been knuckle busting with Chinese crap, you don't know what you are missing.
jimbote
Tacoma 4x4 converted to TDI
i have a pile of $$$ broken snap on sockets, the set is slowly getting replaced with kobalt, craftsman, gear wrench... snap on mostly an overpriced average tool that's main appeal is name, shiny, comes to you, and you can make payments.. i do feel like MAC edges out snap on when it comes to durability... everbody's experience varies, not wanting to start a tool war ;)
I have only ever broken one Snap-On tool, a long 3/8" ratchet, doing something beyond what it was meant to do. I put a pipe over the end of it for extra leverage, should have used a bigger 1/2" one but due to clearance issues I could not fit it in there. That's it. I still have all the same tools I bought new back in the early '90s out of school, most are Snap-On. Obviously added to them over the years, but used daily, repeatedly. I just use their hand tools, all my air stuff is IR with Mac sockets. My electric impact is a Snap-On though.... 8 years old, third pair of batteries... been dropped, run over, sprayed with every kind of liquid you can think of...most recently dropped in a pan full of a G12/diesel/filth mix and submerged :eek: Still kickin'.
My only compaint? The sockets' markings were easy to read when my eyes were younger, now I have trouble. The newer versions have more pronounced lettering and are easier to read. And I am told if I ever actually break one of my sockets (I have over 200 of them) I will get the newer one as a replacement. :eek: I do have some chrome swivels that are getting pretty loose, though. Maybe I should start there. ;)
jokila
Houston, Texas
2003 Jetta GLS, Manual
I bought a set of Craftsman 3/8 drive deep and regular sockets a few years ago that were well marked. Not only in the size of the font, but the fact that all of the markings are on the socket in such a way when you store them in the holder they face the same direction. Seems like a no brainer, but many tools don't even do that simple thing.
Curious Chris
Pineview GA
Jetta Wagon 2003 RIP Rockford IL
I love my Dewalt 20 volt impact wrench it will do 900 ft-lbs going forward. Wish I had had it when I did my suspension refresh and had to change the subframe.
jmodge
Greenville, MI
Ask a simple question, mommy and daddy fight. I did mine with 1/2” and bar. As stated, hardest part is the last 1/4 turn, heavy torque. My opinion, if you break it, then try something else. Be careful pushing on tools in the event they do break
[486]
MN
02 golf ALH
Use a long pipe and when your tools let go you don't smash your knuckles. More torque for less force.
Not just for cheap tools, but a good thing to know for the new 80 tooth ratchets that are so common now, my snap-on ones all pop and snap with the smallest bits of chewed up teeth in them. Sure wish they were still selling 36 tooth stuff when I bought my junk with the student discount...
Guy at the junkyard had one, was zinging off lug nuts that my 18v snap-on ni-cad wouldn't even touch
I did dig it out of the garbage and stuck new cells in the batteries, but still, jeez louise those new impacts got some poop to them.
flee
Chatsworth, CA
2002 Jetta GLS wagon
I'm not a pro by any stretch but I appreciate the feel of a quality tool when I work.
Many years ago I bought a set of Facom French-made sockets, drives and various
hand tools, most notably a set of indestructible angle fixed socket wrenches.
I still reach for these any time a bolt or nut is involved and I've never seen another
manufacturer make anything like them.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
As an afterthought, the answer is Yes, your 1/2" drive stuff will work just fine. You may need a pipe to get 90 degrees.
Vince Waldon
Edmonton AB Canada
... and use the shortest extension on the socket you can... it's going to want to twist as you do the extra 90.
That also means mark the socket rather than the wrench handle to know you've gone 90. :) :)
[486]
MN
02 golf ALH
If doing it on the ground I'd get it out past the wheelwell and on a jackstand, so you can get on it with a pipe
then when stuff breaks you aren't going to bleed
