HOOPER65
Starter went kaput - 2004 PD TDI ...
Could not even rolling bump start a warm engine !!
Question ???
There is ( from what I know ) a sensor that tells the
glow plugs to not flash if the engine is hot .
• Can that sensor be overridden to be turned off
there by flashing the plugs to a warm engine,
there by making it less difficult to rolling bump-start
a warm TDI ??
• I suspect it would have started if I could have flashed the plugs.
As it was, I was in a busy spot and bumping it was very unsafe - tried 5 times in second gear - almost got it - but then the area I was in just got too busy to try it anymore.
Had to flat bed it to the shop - NEW Starter ! ... that's all it was .
Works fine now ... I'm just thinking in academic terms now after the fact ... if there was a better way to have gotten it running ??
Question ???
a warm TDI ??
