timeline
Can the master cylender or brake line cause this? New brakes. Old brakes squealed as well before I changed it. Please advise
TDI Waggon, 2002
Thnx
TDI Waggon, 2002
Thnx
Did you clean and lubricate the caliper guide pins when installing new brakes? If not they won't retract properly when you release the pedal.
Return it. I am not seeing how that could cause the problem. A hose leaks or doesn't and if it was clogged by some weird chance, you wouldn't even have braking, and thus no drag.Yes. We changed it for a known good one. I was told it could be the hose so i bought one. Have not installed yet.
Funny story about my wife's Toyota Sienna. The caliper pin froze into the caliper mount and the pin snapped when I tried to remove it. It was cheaper to buy the complete caliper w/mount rather than just the mount, bolts and the rubber boot (all sold separately). I took the mount with the bolts and rubber boots, and returned the new caliper as a the core. I told the advance auto guys that I was more comfortable using the 12 year old Toyota caliper rather than the new "rebuilt" one.Did you buy new calipers? I had this issue on my work van. when you get "remaned" parts you get CRAP QC. I took the caliper apart to find sand blasting media (3 grains) stuck in the walls of the caliper that where binding the cylinder from moving back. if everything is working and its still an issue, just take the slave cylinder or caliper apart and clean it out with break cleaner and put it back together making sure to oil everything you put back together with break fluid.
Hopefully, you not only cleaned them, but lubricated them with brake grease. It's a lot more water resistant than other kinds of lubricants. It looks similar to the grease used for boat winches and sunroofs.Cleaning the guide pins was quite helpful. Quieter than ever before but still squeaks a bit near a slowing roll. If it gets worse I will report in here later. Thanks all. GB
Thanks. Tried some of that. Where is PNW?Lube pad backing (where pistons contact) and the outer edges of the pad backing ears (metal, very little grease), and slider pins.
Hubs have to be clean. If they are not the rotors won't seat flush and you'll end up with run-out (which will cause pulsing issues- pedal feel perhaps, and or noise).
I have no tolerance for less than perfect brakes. I replaced front calipers, rotors and pads on the wife's car recently because the PO's (commissioned) brake job was crap. "New" calipers were likely cheap crap: may have gotten 50k miles in total. Got to the point that one was really dragging: to the tune of at least 1 1/2 mpg FE degradation. I suspect that the same shop that put on crappy calipers also stripped one of the slider pins (I repaired this about 2 years ago).
That would be my order of attacking this problem.
Be sure to change brake fluid every two years.
With brakes you pretty much have to do everything right. And, as I did, sometimes you just have pitch everything out and start from scratch (with good parts).Thanks. Tried some of that. Where is PNW?
DO NOT put anit-sieze on the pins. You want silicone-based grease. There could be other concerns such as degradation of rubber.stear clear or reman calipers, 2 times i have had to take them apart to get sand from the blasting process they do when they rebuild them. 3 grains of sand in the caliper. ***. STAY AWAY FROM REMANUFACTURED PARTS. its easy to rebuild a caliper, SO EASY, never buy or trade in for another one. copper antisize on all the pins and lub points too. use brake quiet gel on the backs of the pads too.
http://forums.tdiclub.com/showthread.php?t=389265120K miles of use on copper and silver antisieze and never had a boot fail or dry rot due to it. I have used regular grease, garage door lube, ect.
I did have a set of rack boots dry rot and crack in 2 months of use for NO reason what so ever, no oil or anything was on them or leaking. it was just some rip off crap from GAP, i called them and they refunded me and informed me who the OEM suppler was. 80K later and there just as new as the first day out of box.
dont know what you mean or your experience is UhOh but i have never had an issue with antisieze other than trying to get it off my hands. This is what is used on high performance brake sets due to heat issues cooking other products.
