J
- Joined
- Feb 2, 2000
- Location
- VA, USA
- TDI
- '12 passat tdi.... my 6th TDi!! a4, a3, b4, a5, my b7 and wife has a '11 JSW.. :)
For the past 1.5-2 months car has been getting 35 mpg, before that I avg'd 42-44.
when it's been real hot and AC on level 4, car will cut off while in neutral, coasting to a light. it's done that 8-10 times in last month, REAL HOT and ac blasting is only way to recreate.
car threw a check engine light about 3 weeks ago, code was related to Throttle Body/Regulating Flap (BRM), took that part off and replaced it. light came on once and stayed for a couple of starts afterwards, then went away. replaced part 1 week after check engine light went off. it didn't seem to be in bad shape, but wanted a new one since it was only $129. thought it may be part of my cut off/crap mpg issue.
car has cut off twice since I changed that part.
changed tb in march but used both lock tools and ran fine for 2 months after that
looking for someone with vag com or vcds in richmond va now.
what should I look for?
thank you in advace!
