kdawg89
Hi All,
In a combination of stupidness and bad luck I had my valve cover off then had to remove the air box and didn’t cover the valvetrain up. A piece of plastic broken off the little air dam thing and shot over and hit the valve train. I’m not sure if it then shot away somewhere else or ended up in the head. I can’t see it anywhere under in the valve train, if it did go down there I think it went down one of the drain holes in the front of the head. Assuming it did go down one of those holes would it just end up in the oil pan?
