aja8888
I installed a new feed hose from the firewall plumbing (hard pipe) all the way to the front filter input port on the FM100 head. I left slack in it to be able to lift the filter out of the clamp and change it without disconnecting either hose from the filter head.If I understand correctly -- you did not extend the original hoses at all; just used opposing sides of the filter head ports and there is enough slack to raise the filter high enough? If so, that is the clear winner.
The new hose slack drapes through the area bellow the filter head. I used "marine" quality fuel hose which is bio-safe. It has a thick wall and is not very flexible. While it is not as pretty and clean as the above method, I can change a filter in no time.
