Not sure about the front of the pan, but that's the least of this guys worries. It wasn't rod knock, the crank is broke. The #1 web between the crank snout and the first rod journal is broke clean through. The loose idler must have been repeated getting jammed between the crank sprocket and BSM sprocket, stressing the crank.Any damage to the inside of the front of the oil pan? We had one come through that the BSM idler gear was not properly torqued and the bolt cam loose. (The car owner had installed it himself)
It wore a nice divot in the front of the pan before the carnage looked like the pictures above.
I agree. And this clearly was the result of a moron install.I would think buying a VW supplied shortblock at this point would be a bargain.
I had and engine this same problem. I saved the geared BSM and wonder if it's still any good. I might be able to source the damaged gears but not sure if the internals got damaged or not.Any damage to the inside of the front of the oil pan? We had one come through that the BSM idler gear was not properly torqued and the bolt cam loose. (The car owner had installed it himself)
2x. My geared BSM has about 180,000 km on it.I have an 05 with geared bsm and just over 100k-no problems. Remember all it's not what but who.
