Old December 5th, 2010, 11:11   #1
tothemax
tothemax's Avatar
Default Any suggestions for a good 0-50 Boost/ EGT dual gauge?
Looking for a 0-50 Boost/ EGT combo gauge
Love the data logging capabilities of the Autometer ones but don't like the fact that they do not have dual gauges.
Any thoughts on this one? Superchips Lazer Boost & EGT gauge seems to offer some of the same limits functionality as the Autometer but they offer both parameters in one gauge
tothemax is offline   Reply With Quote
Old December 5th, 2010, 12:19   #2
Growler
Got Soot Vendor
Growler's Avatar
The mcnally is an option that is out there. they have 0-50 boost EGT combo gages.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old December 5th, 2010, 12:38   #3
tothemax
tothemax's Avatar
Tnx, I do have McNally right now and it is a consideration but I have had some issues with mine. I may end up going that route. I like the bells and whistles of the Autometer thought. Too bad they do not do a combo gauge.
Old December 5th, 2010, 12:51   #4
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
Ask Justin about his Isspro setup. He can actually log right now (and log A LOT), I would still need to add a box for my Autometer setup to log anything.
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Old December 5th, 2010, 12:57   #5
Honeydew
Isspro makes a 0-60 psi. I have a set in the truck and really like them.
Also, check this out:
http://www.aeroforcetech.com/products_interceptor.html
Honeydew is offline   Reply With Quote
Old December 5th, 2010, 13:00   #6
LukeWilson
Auber instruments combo gauge:
http://www.auberins.com/index.php?ma...7e9b8ccd81e72e
You can't see boost and egt at the same time, but it records what the max value was for each function. The egt is very fast acting and a light comes on when it hits a set value. For the money, i am very happy with it.
LukeWilson is offline   Reply With Quote
Old December 5th, 2010, 13:03   #7
Farfromovin
Torque Addict
Those aeroforce gages seem like a lot in a little package. Too bad it's just not a little more "analog" looking. I'm a sucker for needles, what can I say
Old December 5th, 2010, 13:49   #8
Sc0
Fuel Economy: 46/40/34
I have the above gauge and I like it, records peaks while key power is applied and resets when the car is off.
It does have something that spins inside and hence generates a bit of heat but nothing like a head unit, as for the noise just be aware that it might present itself under certain circumstances. programmable via Rs-232 cable or touch screen. Think I have had it for a few years and no issues.
Sc0 is offline   Reply With Quote
Old December 5th, 2010, 16:26   #9
rocketeer928
rocketeer928's Avatar
I was looking at the same SuperChips boost/EGT gauge about a week ago as a replacement for my flaky McNally. But, what I could not tell is if the SuperChips uses the pressure transducer like the McNally, which would make for easy plug-n-play, or does it use a tube like my old Stewart gauge. Do you know, Pierre?
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
rocketeer928 is offline   Reply With Quote
Old December 5th, 2010, 16:46   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
SPA Design digital boost/EGT gauge.
http://www.spatechnique.com/product_...ils.cfm?id=376
http://www.pegasusautoracing.com/pro...asp?RecID=5976
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old December 5th, 2010, 17:41   #11
ndamico
ndamico's Avatar
the SPA's used to have a bad rep for problems. hopefully they have fixed it.
14 Passat SE 6-Speed
ndamico is offline   Reply With Quote
Old December 5th, 2010, 17:51   #12
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
So far so good with mine the past 4 years. (dunno about newer models)
Old December 5th, 2010, 18:42   #13
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
Stewart Warner Maximum Performance series + 42 Draft Designs light match kit
can't go wrong with those...
02 Jetta, 17:1 CR 81mm ASV, block girdle, ported head, custom Colt cam, IE rods, TT springs, cryo gears, Peloquin LSD, Raxles, FueLab Prodigy pump, 12mm/DE143, HFLOX 5 x 0.013, R32 intake, NX nitrous, 6+6 billet BatMo turbo, Bilstein PSS9 coilovers, BFI mounts
MKVII GTI 6MT, full build, 525hp daily driver. Soon EFR 9174
loudspl is offline   Reply With Quote
Old December 5th, 2010, 18:42   #14
Sc0
The Superchips/MSD uses a transducer, little black box with a short vacuum line attached then a wiring harness goes to the gauge. The thermocouple is I think is standard and has wires that go to the back of the gauge.
Old December 5th, 2010, 20:25   #15
FredS
Fuel Economy: 00 NB-39, 01 Golf-41, 94 Toy-30
Superchips starts at 600? Doesn't that seem a little high to start with, if you cool down before shutting down? I like the looks and concept, would probably want it to start around 300 though.
2000 Beetle, 5spd, RC2, Sprint520s,(daughter's 2nd new car)
1999 Golf GL 2dr, 5spd, TDTuning-Stg4, R520s, SBC Stg2-Endurance, 17/22, WhitBread DP, 3bar MAP
92 Dodge crewcab diesel(custom stretch) 4x4
03 GTI, 2012 Tiguan
FredS is offline   Reply With Quote
Page generated in 0.18300 seconds with 10 queries
[Output: 127.74 Kb. compressed to 106.44 Kb. by saving 21.30 Kb. (16.68%)]
