DanG144
Get together in Winnsboro at Midlands Biofuels July 14.
Tunes,
diagnostics,
food.
http://forums.tdiclub.com/showthread.php?t=354605
Tunes,
diagnostics,
food.
Jetta from the 04 donor. One for sure, two if they are decent and available.Bruce, sure thing. Passat wheels, right?
Wait, I think I remember now, you wanted one wheel for your Jetta?
Dan, I haven't gotten on the forum in a while (which is a good thing), must mean the Jetta has been running really well for me lately. Hope everything has been going well for you.Helped a serviceman today. 2004 Jetta, needed a fuel pump, that fixed many of his symptoms (low power, limp mode.)
But he still has a gremlin in #1 injector, getting an electrical failure code. I am seeing a 16 for injector #1 in MVB 018, as well. Something similar to "implausible beginning of injection."
It looks as if he has an intermittent wiring issue. He will peel out the wiring harness and inspect. Maybe DidJettarun or I can pull the valve cover off and inspect under there as well. The resistance of the coils and wires checked good, of course this is an intermittent issue, so they can check good most of the time.
If we cannot find it fairly soon we can swap two injectors and see where the problem shows up again, to determine if it is the injector itself or the wiring or ECU.
