Digital Corpus
Anyone interested? I received my first prototype boards in the mail today . I made a goof when I had the boards made and don't have a proper groove to allow correct dispersion of light from the LEDs. I'll tweak/dremel the PCBs for testing this and adjust the groove cutouts to compensate. Also, I've not used this LED package before, but it's fairly unique. So much that I have only found it in white. Color temperature is ~5600K white is daylight white.
If you guys want more details please ask. Glamor shot time!
I should note that I only have the ring made from the vent selection. However, this PCB has the same dimensions as the fan speed selection. The tricky board will be for the temperature controls. This prototype is for clearance and brightness and dispersion testing.
