Here's some numbers for you, these were taken from a bully dog, watchdog on my 2009 Jetta TDI sedan (I know this is for MK5, but all cr140 should be similar). First set was stock, second set was Malone 2.0 tune and dsg tune, no exhaust changes. Also, please note first was at 75 degrees, second was at 98 degrees, according to dash temp. Will try again with closer temps. Only other changes in between were ss brake lines, and a 27 mm rear sway, both of which would add weight. This includes my 330lb carcass behind the wheel, plus my my normal cargo (maybe 100 lbs more, hitch) :
60 ft before 2.8 secs after 2.2 secs
0-60mph before 9.2 secs after 7.9 secs
1/8 mile before 10.9 secs / 65 mph after 10.2 secs / 65 mph, no clue why the mph is same
1/4 mile before 16.8 secs / 82 mph after 15.9 secs / 84 mph
FYI, I ran it up to 109 mph (per GPS) and it was still pulling strong. Just not enough road for my comfort level. Later this was pushed up to 124 mph per the same GPS.
Rawtek coming soon for maybe better numbers.
