From what I've read, belts produce more accurate timing than chains. Chains wear over time, the links wear, there is more "slop." Belts such as the ones used by VW do not stretch over time; once the timing is propertly set, the cam and injection timing should not change.Some have said that VW choose a belt over a chain to reduce noise. TDIs idle pretty loudly so I'm not sure how much lounder a chain would be. I'm guessing most would take the extra noise in exhange for a "life time" chain.
Dan, in the early part of the 2001 model year (build date before April 2001, see driver's side B pillar for the build date of your TDI), the old-style timing belt and tensioner were used. 60k replacement schedule for 5-speeds, 40k replacement schedule for automatics.I have a 2001 auto and I've read it can be fitted to have the belt changed at 80K instead of the normal 40k. I think you have to get a different tensioner? I'm not sure, anyone know about this?
You will pay now or you'll pay later. Doing a full and complete job is expensive, whenever it's done. But doing a partial job, and then redoing it again in 30k miles or so, is even more expensive.You may have just saved me a few hundred $
Tornado - I have read here about the build date of April and the engine serial# over 500,000 , but I haven't found a way to double-check this or confirm it from a 3rd party. Contacting VW is like asking a blind man for directions. Can you indicate a source where this is coming from?In the latter part of 2001 (build date after April 2001, the extended-life timing belt and tensioner were used. Good for 80k miles regardless of transmission type.
You've probably read the same threads I have.Tornado - I have read here about the build date of April and the engine serial# over 500,000 , but I haven't found a way to double-check this or confirm it from a 3rd party. Contacting VW is like asking a blind man for directions. Can you indicate a source where this is coming from?
No. Replace the TB, tensioner, rollers and water pump with the parts in the 100k mile kit. Then repeat at 140k, 240k, 340k.....I just looked at my build date, it was 7/00. So I guess it's every 40K for me
If you consult the owner's manual for your 2003 TDI, it will call for replacement of the TB at 100k miles. Not 60k, not 80k. Your service manager is hoping you will do this early; you would be foolish to do so. But when it comes time, then do the whole job, not just part of it.80K timming belt??? I just passed 55K on my 2003 Jetta TDI and I asked service manager about the timeing belt change period for this car. He said not to go too much over 60K. So I figure at my next oil change interval its time to do the belt. I did ask about a 80K belt and he said he has never heard of such a thing, VW's belts are good for 60K only.
Are you guys sure there is such a thing, the last thing I need is for the belt to go.
You have the answer. If you want the answer from a real expert, then ask MoGolf or HermTDI or Harvieux or... I could name a few others. But you have the answer.This has got me excited, but still a couple of questions. I figured I could buy an 98-mid 01 and change to a 80k belt system.... Here it sounds as if I can buy any year and change over to the 100k system. I'll keep looking over this site but can hardly wait for the answer.
Actually... not quite.The first (I stand corrected!) VW Diesels were built for the 1977 Rabbit
Here you go...80K timming belt??? I just passed 55K on my 2003 Jetta TDI and I asked service manager about the timeing belt change period for this car. He said not to go too much over 60K. So I figure at my next oil change interval its time to do the belt. I did ask about a 80K belt and he said he has never heard of such a thing, VW's belts are good for 60K only.
