SootFoot said:
Well, our 2005 Beetle TDI with manual trans does not come up in the VIN database for this recall either. Just for the recall that involves re-programming the ECM but not changing the glow plugs.
jqian, you'll love this. That TSB you mentioned came out November 2008..... March 2009: Our car goes into dealer under warranty for glow plug CEL. They disregard the TSB that is in force and throw an 11 volt (OE is 7 volts) ceramic glow plug in cylinder #1 and call it done.
I only recently discovered the situation because its my wife's car. They now refuse to correct the situation, all the way up through the management.
I opened a case with VOA about it (failure to comply with TSB during the March warranty repair). Wish me luck.
sounds to me this is ridiculous.
The recall letter mailed out recently at the end of july 2009 says
"affected models AND manual transmission" vehicles need to be reflashed ECM.
"all affected models" vehicles need to be reflashed ECM AND replace glow plugs.
First of all, I don't understand why the transmission makes the difference about glow plugs.
TSB as you mentioned was came out last year, it clearly stated all the VIN without mentioning transmission at all.
I called VW of Canada customer care couple of days ago to raise my concern on this confusion. The woman on the phone was totally clueless, but kept saying dealers would do their jobs due diligent, blah...blah....She sounded like blaming me not trust dealers (of course I don't trust dealers!).
VW of Canada or US (presumably) are totally helpless and incompetent. They don't know and don't care what you talk about.
Anyhow, I finally found a local dealership in Toronto that is helpful and knowledgeable and honored everything said in both recall and tsb letters.
