amishman
This happened last year also but it has come up again. Not sure if it was around colder Fall/Winter weather or not but maybe coolant plays tricks when it is cooler. Anyway, couple weeks ago the dash light that shows cold coolant (blue) and then normally
goes out when the 2001 TDI Beetle is warmed up went Red and blinking right after starting up the Beetle in the morning. Maybe 30 seconds after it started. Like I did last year, I added 1/2 cup, maybe a cup, of distilled water, and all was well. I would say my coolant is right in the middle seam of the bottle so higher than the side markers (that you can't see anyway the way the bottle is mounted). Couple weeks go by and the red light blinking came on again. I added a scotch more of distilled water, maybe 3/4 cup, and the light is back to normal blue in AM and then goes out. Again, water level at about 1/2 bottle as best I can tell.
So, is the sensor in these bottles that touchy? Any fixes for this. Obviously adding the little extra water seemed to do the trick so I am guessing the sensor in the bottle, if it has one, is at fault. I did unconnect the cable connector going to the bottle and re-connected. Not sure if that helped.
tj
tj
