I want to drain automatic gearbox oil pot in a 1.9tdi. Check filter. But I'm not sure of right quantity of oil is fir for the box. How many liters PLs? Thanks for your help.
I recommend you also replace the differential fluid. I changed my ATF at 50K but not the differential. No issues until my differential failed at around 100K. Transmission is still going strong at 180K.
