2000 Jetta TDI. So a few weeks ago I tried my ac in my new to me Jetta. The clutch wouldnt engage and the radiator fans wouldnt come on so I checked for low side pressure. I was a little low so I evacuated the system.
Then today rolls around... I pulled a 30 pound vacuum and it held for 30+ minutes. I go to charge the ac system and I only get about 8 oz of the 26 I needed to. The clutch still wouldnt come on and neither would the fans. I finally decided to check to see if my fans worked and discovered that only the high speed on the small fan worked. I ordered new fans because I'm going to need them anyway come full on summer. I also put power to the clutch and it engaged.
My question: will putting in the new fans fix them not coming on or am I looking at replacing a fan control module and an ac pressure switch?
Thanks in advance - Max
UPDATE
I replaced both fans and the ac works fine now
UPDATE
