I've done two of these in the last week. Easy to do if you if your are leaving all the wiring intack, remove two nuts on the drivers side one on the passenger side, four bolts at the base of the console and one behind the windshield wiper assembly. Also have to take the AC and cooling lines off. Entire assembly slides out, then you have to unpin a couple electrical connectors and they can pull through the firewall. Oh yea need to remove the steering column and console.
If you are taking the dash cover off and leaving the wiring and frame work behind make sure you remove the passenger airbag that what hung up on me when I did the first removal.
