Been a lurker for years. Love you guys! Love the community!
Long story short, TB broke while driving, car sat for about a year. I finally got it and have the timing belt put on. Everything is spinning freely by hand. Even hear the compression building and releasing. I may have lucked out.
The car still doesn’t want to start. I’m concerned I am not locking the IP in the correct “just get it started” position. My question is this...
When the cam and crank are locked in TDC, what position should the IP pin be placed for it to be in time? I am doing this after the belt broke so it’s not as easy as I’ve been finding where everything was already in time. I’ve read that the pin should be placed around 1 o’clock on the pulley. I can’t seem to find a position anywhere near 1 o’clock where the pin slips all the way in to lock it. The closest I get is around 2 o’clock but the pulley still rotates quite a bit with the pin in. Am I explaining that well enough?
Any help would be greatly appreciated. Just need my beater MPG machine back on the road! Thanks in advance!
