Steve Addy
Anyone with a Mk3 that's been underneath their car working on something knows by now that the body plugs used in the rockers (and elsewhere) are pretty cheap. The ones in my 97 TDI (and I think in the B3V too) are just molded plastic and they don't stand up well over time, and finding replacements from other VWs, well, that was basically a dead end in most cases because they all used the same ones.
So for quite a while now I've been looking around the JY for body plugs from other makers that are rubber and provide a better fit.
VW claims the hole is 30mm (there are other sizes too) and so far the following plugs from other makers seem to be a good alternative. They are rubber and decent
GM 94535738 - This was found in quantity on Suzuki Esteem (maybe 10 per car) but was used on other cars too. These are technically sized at around 31-2 based on measurements but listed online as 35. They fit is tight but worth the effort as they won't fall out.
Toyota 90950-01958 - This plug has a 30mm marking on it but online it is listed as 31.5 size. It's a good alternative but after scouring a number of Toyota models I could only find a few, and the models that use it only have 1-2 per car. The fit is also not as robust as the other but it's easier to install. While it fits snugly I wouldn't be surprised to find it missing after a while. It's better for vertical installs and I might use a tad bit of rtv on it.
I resorted to this after trying to find a bulk vendor for 30mm rubber body plugs online and all I could seem to find was assortments, none of which included any in the 30mm size (or close enough to work).
If anyone has found a good source for replacements please post up, I'm interested in getting these holes plugged on all my cars so that garbage doesn't accumulate up in there. I'll also be looking at alternatives for other sized body plugs, there are some 40mm ones too but I haven't looked for anything in that size yet.
Steve
Steve
